Author Topic: How do you fill gas without spill !!!!  (Read 2696 times)
KON DEE
  • It's not just a bike, It's my baby !!!
« on: January 17, 2005, 12:45:02 PM »
Today I got my bike out for a short ride. I took the PCH Route South to Laguna Beach and back to Seal Beach. I put pretty good mile on the bike, around 60 miles and 3 hours  ;D. However, I didn't not ride to eat but ride to drink this time  :P(short stop for starbuck).
Back to the topic, this is second time I spilled some gas on my tank :'(. The first time only just a few drops when putting the nozzle back to place, but this time is something really bad. I got the nozzle that need to push hard in gas tank to get the gas out, if I lift it up to see inside while filling then the gas won't come out (disengage). I then thought that It will automatically shut off after the tank full since I cannot look inside and fill at the same time. You know what happended, it didn't not shut off and the gas spill all over my gas tank after full. This is really suck :-/.
« Last Edit: January 17, 2005, 03:15:07 PM by VStar4Life »
Nationality: Thai
Tony
  • I rode: '04 Ninja 250R
Re: How do you fill gas without spill !!!!
« Reply #1 on: January 17, 2005, 01:31:24 PM »
For gas pump nozzles that require you to compress the vapor guard** for activation, I pull the vapor guard** back with my hand so I can still peer in to the gas tank.
Also it helps to wait a few seconds before withdrawing the nozzle. Then slowly withdraw the nozzle and shake lightly over the opening before replacing on the pump.
*no sex jokes please PETER
**thanks JC - I couldn't remember that term
« Last Edit: January 17, 2005, 04:02:51 PM by trueblue »
  • Loves to Tinker
« Reply #2 on: January 17, 2005, 03:31:07 PM »
Exactly as stated above.  Modern gas pumps have vapor guards on the nozzle to ensure that a superfluous amount of gasoline vapors are not being ejected into the local environment which could cause a fire hazard.   The solution to this is to pull the rubber around the nozzle back until the pressure point (or however its triggered) and then only put half the nozzle into your tank.  That way you can visually see when you're close to topping off.
Good luck :)
flstc2003
  • Guest
« Reply #3 on: January 18, 2005, 03:21:57 AM »
Here is a little tool that helps hold the vapor guard up out of the way.
http://www.aerostich.com/riderwearhouse.filereader?41ed35c1147d2492271dd1f0ec0706e4+EN/products/2818
DMM
  • Hair By Helmet
« Reply #4 on: January 18, 2005, 03:37:09 AM »
flstc2003 - does that tool really work?  As you know, I've ridden through/by-passed gas stations when I've seen those vapour guard muzzels to cross to the street to a station that doesn't use them.  :)
I'm not totally useless; I can be used as a bad example.
I'm not your type.  I'm not inflatable.
Therapy is expensive. Popping bubble wrap is cheap. You choose.
Wildgift
  • this is the modern world that i've heard about...
« Reply #5 on: January 18, 2005, 08:40:04 AM »
must..resist...jokes...
but what to do with terms such as :
...little tool...ejected..."pull the rubber"..."slowly withdraw" (personal favorite)..."shake lightly"..."push hard"...topping off (isn't that some british slang?  and if not, why not?  discuss.)..."fire hazard"
what am i, made of stone?  i need a cold shower!
in eny event, JC has it exactly right...good job, jeff.
boy, you guys drive a tough bargain :P
Weddings, parties, anything... and bongo jazz a speciality...
KON DEE
« Reply #6 on: January 18, 2005, 10:45:39 AM »
So let me get this straight.
Pull the rubber, put in only half, look through the hole, ejected, after finished shake lightly and slowly withdraw. Is this correct? ;D
Well, I'm no English so you guys gotta forgive me if I use the words incorrectly. ;)
« Last Edit: January 18, 2005, 10:47:26 AM by VStar4Life »
Nationality: Thai
flstc2003
  • Guest
« Reply #7 on: January 18, 2005, 04:34:07 PM »
Quote
;D ;D ;D ;D ;D ;D nearly nasally evacuated my ice tea on this one. ;D ;D ;D
Quote
Posted by: mahoneyms Posted on: Today at 8:37am flstc2003 - does that tool really work?  As you know, I've ridden through/by-passed gas stations when I've seen those vapour guard muzzels to cross to the street to a station that doesn't use them.  Smiley
We are both gonna find out find out in a few days, I ordered us both one this a.m. A little  Epiphany present for you.  ;)
depotdog
  • Embarrassing Noob
  • Some kinds of happiness are measured out in miles
« Reply #8 on: January 21, 2005, 05:56:30 AM »
I do just like Trueblue says, except I also juggle a paper towel to catch the dribbles at the end. Quite the multitasking event I can tell you. I originally got a great post on the womans BB forum from Cindy who described how to fill the tank. I have never splashed lots of gas, but I have had it splash a little from inside to leave tiny droplets on the tank. It seems some of the stations have more graduated pressure than others. I hate when the gas seems to only flow at full force or off, with nothing inbetween. >:(
Tricia
Yamaha V Star 650 Classic
DMM
  • Hair By Helmet
« Reply #9 on: January 21, 2005, 07:29:08 AM »
Quote
Too cool!!!!  We can report back our experiences to the MOs.   :)
KON DEE
« Reply #10 on: January 21, 2005, 09:33:20 AM »
Yup that what I use the paper towel to prevent the dripping (after the incident). I also experience that some nozzle will automatic shut off after the fuel level in the tank reach the tip part of nozzle but some don't (the one that got the gas all over my tank :P).
Nationality: Thai
flstc2003
  • Guest
« Reply #11 on: January 21, 2005, 06:15:37 PM »
The little tool has arrived ::)  As with all little tools it is a bit of a let down. I think with a pair of tin sinps and the correct dimensions I could make one from a scrap of metal. Will see how it works when I get the hog out of the shop
Bob
DMM
  • Hair By Helmet
« Reply #12 on: January 21, 2005, 06:48:49 PM »
flstc2003 ~ thanx for the hilarious description!!!   ;D
DMM
  • Hair By Helmet
« Reply #13 on: January 24, 2005, 03:36:58 AM »
Used "the fuel tool," yesterday.
It is small & easily fits into the pocket of any bag.  As mentioned, it's lightweight & now that we have one, a template could easily be made if people wanted to cut their own.  Although it was like I needed 3 hands to initially get it on the pump, once on, it worked well.  I'm sure with more use, I'll figure out a 2-handed installation system. :)
Wildgift
« Reply #14 on: January 24, 2005, 11:43:43 AM »
bob speaks with what appears to be the voice of experience about the disappointment of little tools!! :D
http://www.enzyte.com/nme.html
maybe this is in order!!!
