Author Topic: Buying a new bike, need advice...  (Read 1105 times)
30-30
  • Guest
« on: April 20, 2005, 09:19:15 PM »
 Hi guys!
I am approved for a loan, and I am trying to decide between a V-strom 650, and the yamaha FZ6.
How are you V-strom guys liking your bikes? I have never owned a Suzuki before. I don't know what to expect from one.
Any problems at all?
Any advice would be much appreciated!
-Chris
  • Loves to Tinker
Re: Buying a new bike, need advice...
« Reply #1 on: April 20, 2005, 09:39:45 PM »
big engine differences...
vstorm = vtwin
fz6 = i4
Fz6 is gorgeous with undertail exhaust.    Runs 11.30 qtr mile tho, .6 faster than sv.  but you have to worry about the buzzier power band i hear.    vstrom should have much smoother linear acceleration.  Steve owns vstrom, should be able to comment.
vstrom is also a hot bike. but very different look than fz6 I think.   Would like to sit on the fz6 but insurance probably higher than sv, plus I like the vtwin engine.
Wildgift
  • this is the modern world that i've heard about...
« Reply #2 on: April 21, 2005, 07:47:58 AM »
+1 JC
fz6 is a standard, and compares to the sv650, th kawa 750 and the honda 599. the word is that the power is all in the high end, so you need to wring it to get it to scoot, though they say it is quick when ridden this way.
the vstrom is an "adventure" type machine similar to the BMW 650 or the ducati multistrada 620. sAm like his last time i heard, but its a very tall bike, and will be less maneuvrable in slow speed situations.  it has the same engine as the sv650,which is a smooth, tractable twin.
hope this helps.  you really are comparing apples and giraffes, but i've been there and done that, and wound up with something different anyway.  caliguy likes his bmw--check that out too if you want to go tall
Weddings, parties, anything... and bongo jazz a speciality...
30-30
  • Guest
« Reply #3 on: April 21, 2005, 12:51:36 PM »
Heya,
Thanks for the help.
Yeah, I think I am going to get the FZ. It seems like it would be better getting through tight traffic, and such.
And I have to spank the Seca II to get it to scoot, so I kinda know what to expect from it. :)
sAm
  • Guest
« Reply #4 on: April 21, 2005, 01:29:03 PM »
As a VStrom owner, here's my .02:
You'll never go wrong with the VStrom 650 or the FZ-6. Here are some points to think about:
VStrom is on the heavy side.  It's dry weight is 418#.  It share's a lot of parts with the dl-1000.  Also, the weight is pretty high up.  As much as I love my bike, leaning into a turn, I can definatly feel the top-heavyness.  The COG feels like it's right between your thighs (the gas tank, folks ::) ).  BUT the gas tank is 5.7 gallons on a bike that get's aprox 45-50 mpg (depending on how hard I ride it ::) ) so it goes a long way.
The exaust is up high so putting side hard cases will make your bike so wide, lane-splitting is out the window.
It's a tall bike.  So if you're under 5' 11", straddling the bike might get difficult.  I'm 5' 11" with a 29" inseam and I can straddle the bike with the ball's of my feet on the ground.  BUT, it's great for commuting since your head is almost at the same level as the SUV's out there.
The seating is just about straight up standard.  It's comforable.  I'm able to sit on it for 150 miles (i usualy get 180 - 200 miles out of a tank) before I have to get of and rest my hinny.
The engine is a dream.  Tough, reliable, and powerful.  It share's the same power plant with the SV-650.  It pumps out about 65 - 70 HP.  I'm 340# and it will accelerate me up the 405's Sepulveda Pass as well as any mountain road.  It's a re-tuned engine so the max speed is 115 (I suggest nothing over 100.  The bike tends to complain a bit, or it's the wonderful Los Angeles roads.) but the torque is out of this world for such a small engine.  In my learning phase, I've lugged the engine through turns in fourth gear at 2000 rpm.  The engine chugged, but it kept on going.
The windshield  is adjustable over three positions.  At the highest position, the windshield is positioned perfectly to put a ton of turbulence on the forehead of your helmet.  So either have it all the way down, take it off, or replace it.  This windshield hase been getting a lot of good reviews.  It's the next purchase for my bike.
All-in-all, it's a great all around bike and a ton of bang for your buck.
As for the FZ-6, here is what I know about it:
There are not as many suspention adjustments.  The front fork has no adjustments at all.
The engine is an in-line 4  pumping out 90 HP.  The engine needs to rev up pretty high to get to the good power band and stay reved.
The exaust is under the seat, thus side bags don't stick out as far.
the seat has a definate foward lean a-la-sport-bike.  But not as much as a chrotch-rocket.  I'm not sure how comforable it is on a long ride, but I found that when I changed my handlebars (resulting in a bit of a foward lean) my bike became more comforable and quicker to maneuver.  It took some weight off my tail end and back.  So it's a matter of preference.
It's a smaller bike than the VStrom but it's also a bit heavier. However, the weight might be distributed lower (frankly, I don't know).  Also, the seat is a bit high, like the VStrom.
All in all, you wont go wrong with any bike.  So it's a matter of preference.  Check out both and you'll know which one you want.  They are very simular but worlds apart.  I did just that and the VStrom was the bike for me.  Your results may vary.
Good Luck  :)
flstc2003
  • Guest
« Reply #5 on: April 21, 2005, 02:56:56 PM »
883 Sportster
$6,5000  Chicks Dig it
« Reply #6 on: April 21, 2005, 03:14:52 PM »
But it has no passenger seat, even if chicks dig it, they can't ride with you on it.
sAm
  • Guest
« Reply #7 on: April 21, 2005, 03:16:07 PM »
Also, you may as well be sitting on a block of granite.  That's one hard seat on that thing. :-X
Forget about Harley's, buy a Suzuki instead ;D
flstc2003
  • Guest
« Reply #8 on: April 21, 2005, 03:19:45 PM »
Zerog~ Harley riders don't bring the chicks back home to meet the wife!
SaM~You get a but massagie from the chick before you take off.
Bob
sAm
  • Guest
« Reply #9 on: April 21, 2005, 03:22:28 PM »
Well, I guess experience trumps us all ;D
  • Loves to Tinker
« Reply #10 on: April 22, 2005, 09:47:38 PM »
Rofl
  • Loves to Tinker
« Reply #11 on: April 22, 2005, 11:48:17 PM »
